You must configure an MKA profile globally before you can apply it to a port.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitethernet 1/3 Switch:1(config-if)#macsec mka profile test030519
The following table defines parameters for the macsec mka profile command.
                             Variable  |
                             Value  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}  |
                             Identifies the
                                    slot and port in one of the following formats:
                             WORD<1-16>  |
                             Specifies the MKA profile name. An MKA profile name consists only of alphanumeric characters (0-9, A-Z, and a-z). The profile name is case sensitive.  |
